Greetings!
I have a 95 NA 850 with 190K. Been a good car, but I'm having a reliability issue.
When the engine is cold, the car drives great, and the idle is solid.
However, after the engine warms up, the idle is erratic, stumbles, and the engine stalls. As long as I give it gas, the engine is strong. Only the idle when warm is a problem.
I've cleaned the throttle body and butterfly, but no change.
I'm planning on doing the PCV replacement this weekend, as well as replace the vacuum lines.
What are the odds that this will also fix the warm idle problem? Are there other areas I should look as as well?
I appreciate any additional suggestions!
Idle Stalls When Warm
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Vacuum lines may help. Once the car warms up it goes into closed loop mode and judges readings based on O2 sensor and mass airflow sensor values. Air leaks can throw off the fuel/air mixture and cause your car to run like crap.
'98 S70 T5
2016 Chevy Cruze Premier
Billc1015
- Year and Model: 1994 855 turbo
Have you checked to see if there is any black smoke coming out of the exhaust? It's possible your MAF is on its way out and giving false readings causing a richer mixture. When cold it would run fine because it needs more fuel when vold but after warming up, the extra fuel would cause symptoms like you are explaining.
I am here: http://maps.google.com/maps?ll=40.334552,-75.130673
- 16 Replies
- 8488 Views
Last post by valvolvo70
- 61 Replies
- 11943 Views
Last post by balzybenzy
- 3656 Views
Last post by 93ForMe
- 18 Replies
- 5862 Views
Last post by regent
- 722 Views
Last post by Vovo_merz
