EVAP major leak
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
dtropnevad05
Year and Model: S-80, 2001
EVAP major leak
Post by dtropnevad05 »
Posted this in another post but did not get a reply. My question is is this usually the EVAP purge valve or the hose. The car has less then 70K with the 2.9.
Andrew I also have the same code "EVAP major leak" however I have not taken it in. Before I order your part # 9470775 is there anything else I should look at? I understand there is a hose somewhere near the right rear of the car that also can go bad? Have read something about a recall campaign for a software update if you have a certain code stored? I talked with the local Volvo stealer and all they will say is bring it in we will charge you $235 OMG and if it is covered your good if not you pay! Volvo seems to have the same problem with their dealers that the Domestics have. Oh BTW do you have the o-ring kit for the dreaded body clunk under the front seats? Would like to replace them before the snow fly's here in NW Ohio.
Anyway thanks for any help.
