low heat in cabin at 32f outside.
iceracer
Year and Model: v 70 1998 N/A
Post by iceracer »
Hi There:
I have a 98 v70 non turbo 5 speed.
This morning I was driving to a job site about 40 minutes north of where I live.
The car had been in a heated garage over night. About halfway to the site, the air coming out of the
heater started to cool and the temp gauge for the engine started to drop. Outside air was around 32F.
On the return trip home tonight, the temp at the job site was around 32F.
The engine temp hovered just above the minimum and the air out of the heater was warmish, but
it was cool in the cabin. Had it not been for the seat warmers, I would have to put a jacket on.
As I got closer to home, the outside air temp rose to around 34F. About 5 minutes from home the engine
temp came up to normal range and the heat out of the heater was nice and toasty.
Any ideas as to what may be causing this anomaly?
Thanks, Terry
applcor
Year and Model: V70 1998, 240 1990..
Post by applcor »
Sounds like the Thermostat stuck in the open position for awhile, then about the time you got home it came loose and started functioning properly again. You can bet it will do it again, but it might be a good while. If it does it again the thermostat needs to be replaced. At least that is much better than it sticking in the closed position though!
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Agreed! Lucky it failed open.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
iceracer
Post by iceracer »
But the car operated fine at first, after having been in the heated garage overnight. Once the outside air was around 32F did things change.
At around 34F it operated normally too.
I've heard, but do not know for certain that it could be some type of sensor that regulates the AC from operating below freezing?
Terry
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
It's the thermostat. The engine temp is rising or falling depending on how much airflow is going through the radiator. High speed = more air = cooler engine.
The thermostat should open and shut accordingly to maintain the coolant around 190-200 degrees.
Go with a Wahler OEM thermostat so you don't get an aftermarket one that can fail shut in the closed position and overheat your engine in a matter of minutes.
'98 S70 T5
2016 Chevy Cruze Premier
iceracer
Post by iceracer »
I have access to a Calorstat, or a BEHR thermostat. One is an 87 or 92C version.
My car is a non turbo 5 speed manual 2wd.
Terry
jblackburn
Calorstat is a good brand, temp doesn't really matter. For what it's worth, though, 92 is standard for non-turbos, 87 for turbos.
'98 S70 T5
iceracer
Post by iceracer »
Thanks for the info. I contacted a local Volvo dealer today.
By the time I order this one piece online, It'll cost just as much as to get it from the dealer.
31.00 cdn. for an OEM version.
Appreciate all the feedback, I'll post results once done.
Terry
iceracer
Post by iceracer »
Thanks for the words of advice. It was the t stat.
I've attached a pic and you can see where the bracket broke.
Put in a new OEM unit (wahler) and it's running fine again.
The DOM stamped on the old one was 08 03 so it must have been changed by the previous owners
at some point as well.
The old unit was also a wahler unit. It was a pretty easy project and I changed the antifreeze while at it.
Thanks to my good neighbor Pete, who has an awesome set of just about any tool needed. He had the right size torx bit for the housing bolts..T.
jblackburn
I bet it's nice to have heat again! When my thermostat broke (I didn't really notice until it got cold), the heat coming out of the car was almost as pathetic as the heat pump at my apartment.
'98 S70 T5
