I was perusing the googles, found a site that stated I could replace my stock GLT turbo with Mitsubishi TD04-16T B5234T3 240hp 1999-2000 tilted outlet...
This was the site:
http://www.wothrline.com/Cars_engine/HW ... harger.htm
My car has a 13t, is auto, and looks to need the above referenced Mitsubishi TD04-16T B5234T3 240hp 1999-2000 tilted outlet...
What's the procedure? Where would one aquire these parts? Does it require ECU tuning?
Thanks!
Mitsubishi TD04-16T on a V70 GLT?
precopster
- Year and Model: Lots
- Been thanked: 128 times
If a bolt-in swap could instantly provide that much power for you it would be great.
The GLT you drive, however has a lower compression larger capacity motor named B5254T.
Even though a larger turbo would yield some results you would have to have a specific tune via ECU for your particular setup. Call IPD and ask them what setup is best for you and how to maximise your engine's potential.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Get ahold of Lucky from ARD for tuning info. All of his tunes are custom tailored to you setup, IPD's are off the shelf. I have one of his and like it over the IPD I was running at one point.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 748 Views
Last post by reGSPlmNjn
- 2788 Views
Last post by jmscdgn
- 315 Views
Last post by jonesg
- 910 Views
- 4448 Views
Last post by FLXC90
