850 idling and running BAD
gcj
Post by gcj »
my 1994 850non turbo will run for a while and then run rough and stall and lose power.
3 shops have had car
put in
egr, mass air flow, trans,idle air ,timing belt, wp,
still same problem sometimes same day somtimes 8 days later
HELP PLEASE
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1255 times
Post by matthew1 »
Go to search, type in camshaft position sensor, check the radio button Search for all terms and read what comes up. It's a likely candidate.
Also -> Amazon link
White850Turbo
Post by White850Turbo »
It seems very likely that you would have some codes stored. CMP usually throws a code, at least in my personal experience it has. You should check them to pinpoint the location.
-Sean
1998 S70 T5 (Almost Stock)
Guest
Post by Guest »
"3 shops have had car
put in
still same problem sometimes same day somtimes 8 days later"
My condolences. Look at the bright side, you're supporting our oil-based economy and they all made money! The consumer unfortunately will never have any recourse aginainst, "Well, it may be THAT (the repair STILL needed) too, but it was also THIS (the needless repair) contributing to your problem".
gcj
Post by gcj »
White850Turbo wrote:It seems very likely that you would have some codes stored. CMP usually throws a code, at least in my personal experience it has. You should check them to pinpoint the location.
all the things already replaced are from codes, now there are none in stystem at all and still runs BAD.
Thanks for all the input
so far
