key stuck and gear selector sticks in park Topic is solved
wonlov100
i have been unable to shift my car out of park without using the shiftlock release for about a week. now my key is stuck in the ignition. can anyone help? thanks.
Guest
I have a 2000 S70 had a similar problem when my key would not return to the O position so I can remove it after turning off the ignition, putting the gear in Park and putting on the parking brake. The furthest the key would go was in between O and I. I could go all the way to II and turn on the ignition. This happened when I was quite low on gas and thought it might be a precaution for low gas. So I got gas, but still it wouldn't budge. So I turned the ignition on and off again, and then it came out.
However, I have been low on gas recently, and my key and the ignition did not have any problems. Tempermental.
White850Turbo
- Year and Model:
Another possibility is the mechanical portion of the ignition switch.
-Sean
1998 S70 T5 (Almost Stock)
Guest
i found out what was keeping the key in the ignition. in order to get my car out of park i had to press the shiftlock overide button. from overuse this button did not spring up and therefore the key would not rotate to the release position. as far as the reason i have to use the overide button in the first place is still a mystery. i am taking her to the volvo service dept.
northeastfreak
- Year and Model: 850, 1997
My key was stuck in my ignition for a few days before reading this thread. I pulled up on the Shift-Lock-Override with my fingers and the key came right out.
I have never used the override before and was probably sticky due to years of coffee being spilled into it. The button was up so high that it didn't even seem to move when I pulled on it, but it let the key out anyhow. The tollerance between, key or no key must be tiny.
I came across the same problem today. I don't remember why I pressed the Shift Lock Overide button but I did. The key got stuck for a good part of the day. However, it came out when I got home. After reading this post, I experimented with pressing the button and it locked the key in the ignition almost every time. Thanks for this forum and the postings. It saves me a trip to the shop and at least a hundred dollar just to have to it looked at.
This also happened to me. The culprit turned out to be the button on the gear shit you press to move the lever out of park, It was broken around the pivot. I ordered a new one from euro parts and the problem went away. It is very simple to replace. Just follow the instructions that come with the repair kit.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Cars with automatics are trying to keep you safe. They've been designed with an interlock that requireswonlov100 wrote:i have been unable to shift my car out of park without using the shiftlock release for about a week. now my key is stuck in the ignition. can anyone help? thanks.
the driver to depress the brake in order to get the shifter out of park. It's a simple electrical circuit that
has three basic components: A switch at the brake pedal, a switch in the shifter and a solenoid in the shifter.
You didn't tell us what you drive, but I'm posting some '98 70 series info.
They're all very similar up to 2000. Here are the relevent diagrams: When the key is on, relay 2/6 is energized ( That's the relay numbered 106 ) and power passed
through C/29 ( fuse #29) and then becomes present at the brake pedal switch, 3/9.
When you hit the pedal, it's next stop is the unmarked normally closed switch in the shifter.
It's there to be sure that solenoid 8/36 doesn't get triggered everytime you hit the brakes.
It only passes 12 volts on to solenoid 8/36 when the shifter is in park.
The solenoid's last a lot longer that way.
It could be the relay or the fuse, but other things get power from those and you'd probably notice.
The switches are the parts that fail most commonly. If either of these switches is inop, the solenoid
won't get triggered and the shifter remains locked.
Often, the one in the shifter ( that's sometimes referred to as a "microswitch") is the culprit.
IPD sells a replacement and has a great picture! Here ya go:
http://www.ipdusa.com/Volvo-S70V70-1998 ... -813-3109/
The button is there in case something electrical goes wiggy.
It's not unusual for it to get gummed up and not release all the way, keeping your key hostage.
Be sure that it's pulled all the way up and you should get your key back.
- 1125 Views
Last post by lummert
- 971 Views
Last post by johnrapier
- 2527 Views
- 505 Views
Last post by RickHaleParker
- 13053 Views
Last post by viriia
