Stalling out after filling tank 94 850
ckrussell
Year and Model: 850 1994
Post by ckrussell »
Vehicle stalls out at takeoff's after filling the tank. I think it may be the evap purge valve but cannot find it. Looked on the radiator where I have seen other mounted and it's not there. I have an identical parts care and looked there as well. My friend has a 97 and it was mounted on the radiator as others have described. Anyone have any ideas?? Thanks
1994 850 N/A 193,000 miles
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I noticed early on that my '94 would do the same thing but I was used to rounding to the nearest dollar when filling up on my Suburbans. I now let the pump run until it clicks and just quit, the problem went away.
I think what happens is the evap lines get filled with raw gas which in turn gets sucked into the charcoal cannister rather than vapors.
ckrussell
Post by ckrussell »
Yeah, I always let it click off when I'm fueling. I've never topped it off. It is running really tough after fueling.
ckrussell
Post by ckrussell »
According to these diagrams it doesn't look like the 94 year non-turbo has a purge valve? Is this possible?
https://docs.google.com/viewer?a=v&q=ca ... eM07ZvbVUw
ckrussell
Post by ckrussell »
Now throwing code 1-1-3 and 1-5-4 and running like crap....
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I used to have the same problem due to me topping it off when getting gas.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
ckrussell
Post by ckrussell »
I don't top it off plus it's running poorly all the time now
ckrussell
Post by ckrussell »
Went and checked my egr valve by blowing into the vacuum line and I could hear what I thought to be the egr valve closing and opening. Also with car running, when I blow into the egr vacuum, the vehicle sputters. When I first cleared out my cel codes I had some Fuel codes come up but they haven't returned. I'm wondering if it's possibly the fuel pressure regulator? Any thoughts would be greatly appreciated
ckrussell
Post by ckrussell »
Rule #1...Always start with the simplest solution. Fuel filter swap and running great. I changed it last year and didn't expect it to be a problem already
