Hell all. I am new to the forum. And frankly, working on cars. Anyway.
I have to replace the entire thermostat housing on a 2002 s60. I am obstructed by other parts when trying to get at the Torx on the bottom portion of the housing. Any tips or suggestions on how I can get to this thing would be greatly appreciated.
Happy New Year!
Replace Thermostat Housing - 2002 S60
JRL
- Year and Model: Several
- Been thanked: 16 times
Unfortunately you need to remove a couple of those parts that are in the way first
Make SURE you put the housing gasket on the right way and use anti seize on the threads, these things have a habit of rusting
Thank you JRL. Re the anti seize, that is for reassembly? I have some PB Blaster for removal. On the parts removal, are you willing to be more specific? It seems like alternator or belt tensioner (maybe) are in the way. Heck, maybe I just need a special tool?
I don't want to take this to the shop. They want $542 (they would have gotten the part w/ that quote) to do this repair. Ugh.
johngasstation
- Year and Model: v70 2002
Hi, I replaced mine recently.
I found a torque screwdriver bit bent to 30 degrees 1 inch from the end did the trick for the bottom one.
To get to the next one back, use a quarter drive ratchet with 3 inch extension.
A little bit fiddley, but can be done without removing p/s pump and other parts.
I have done this myself!
Hope this helps
Hope this helps
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
anolds60 wrote: I don't want to take this to the shop. They want $542 (they would have gotten the part w/ that quote) to do this repair. Ugh.
That's the reason Volvo will only be memories one day. Everything done at the dealer comes in numbers of several hundreds. They don't realize they are chasing customers away.
- 1865 Views
Last post by kahl
- 14 Replies
- 3577 Views
Last post by ktuuri
- 2036 Views
Last post by F250
- 649 Views
Last post by Foursightho
- 2466 Views
Last post by cn90
