2001 Volvo S80 T6 Spongy Brakes
VolvoS80Joe
Year and Model: S80-T6, 2001
Post by VolvoS80Joe »
My brakes are spongy but they stop... eventually. Firm when pumped up with engine off. Soft when engine is started.
I have replaced the following:
(1) Flushed and bled system with power bleeder - no change.
(2) New front rotors, pads, hoses - no change.
(3) New Master Cylinder and power bleed - no change.
(4) low mileage Booster and Master Cyliner and Power Bleed - no change.
(5) No leaks observed anywhere. Fluid level remains constant.
ABS works. DTSC On or Off. No defect indication on dash. Don't have reader for anything other than engine or transmission. No codes from Acton Scanner.
The only thing left is the ABS Motor and Controller?
Maybe the used Booster (2004 43K miles) is also defective?
System has been bled on 3 seperate occasions.
It is the right one for a DTSC System.
Any ideas?
Thanks,
-Volvo S80 Joe
shailey
Year and Model: 2005
Post by shailey »
Could be one ore more of the brake hoses.
Steve
2015 S80 T5
2005 S80 T6 (sold, too many problems to fix)
2001 XC70 (sold, now a college car)
1997 850 T5 (sold, then totaled by an oak tree)
1986 960 Turbo (sold)
1984 240D (sold)
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
If it was a brake hose/line it would lose fluid. You could have a pin-hole leak and get air into the lines.
But the fact that its firm when off and spongy when on suggests a boost problem.
I think you have a vacuum leak or a weak boost unit.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
VolvoS80Joe
Thanks for the comments.
I forgot to list the Front Hoses are new.
I have a new (used) ABS Controller with the aluminum distribution block and plan to swap it out this weekend.
Will the ABS controller work or must I use my original one? If so, should I send it out for repair?
I do not have any light on the dash board.
BerniniCaCO3
Year and Model: V70XC / 2001
Post by BerniniCaCO3 »
Hah! I am remembering when I was even more of a noob than I still am today, and had a spongy pedal after doing brakes and a brake flush. We even replaced the master cylinder in desperation, before it turned out, I'd put the little damping springs on the outside of the calipers on the wrong way!
They were prying the floating caliper body away from the rotor, rather than holding it against it, giving the caliper piston significant extra travel distance before it hit the rotor, and it manifested as a pedal that sunk awfully low before you got real braking power.
I was so humiliated!
So... not to condescend, but not to overlook something so simple either. Is it possible that when you put the retainer springs back on, you didn't do it the same way it came off?
