98 V70 T-5 Manual Transmission
dbm123
Year and Model: 1999 V70 GLT
Post by dbm123 »
I know these kind of questions get asked often, but please indulge me. I am looking at buying another V70. This one is a 98 T5 with a manual transmission. What are the top things I should be concerned about when deciding to buy or not? Mileage is 150K....
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Same as you would with an automatic; but check out the synchros at ~4000 RPM between gears. The change from 1-2 can grind sometimes as well as 2-3.
Other than that:
-MAINTENANCE RECORDS!!!
-PCV
-Timing belt
-Road manners
-Odd tire wear patterns
-Does the AC work?
Most don't need a clutch til around 200,000 unless it's been abused.
I wish they'd made more T5 sedans with a manual - you seem to see them a lot more in the wagons for some reason. Not sure if that's true in the numbers produced or not.
'98 S70 T5
2016 Chevy Cruze Premier
Burn-E
Year and Model: 1998 C70 HPT
Post by Burn-E »
Actually, the 98-2000 T5 numbers and my own experience in tracking the sales of these models is that there are FAR more sedans than wagons with the manual transmission. I don't have the exact production numbers in front of me but I see 10 used S70 T5Ms on the market for every 1 V70 T5M.
Edit, here are the numbers for S70 T5M:
1998 : 361 cars
1999 : 197 cars
2000 : 75 cars
for the V70 T5M:
1998: 127 cars
1999:
2000:
Can't find the numbers for the other two years right now but suffice it to say they followed the same trend as the S70.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Where did you get the wagon numbers?
From what I've been told a LOT less
About 50 for 1998, and only about 20 V70T5 manuals for 1999
