I finally took care of the last leak on my car - the lower radiator hose was dripping from where the clamp had bit into the hose too much and was beginning to leave bigger and bigger puddles under my car where I park.
John (JDS60R) told me about the Gates heat-shrink radiator clamps at Carquest, so I went out and got one (they're about $5 and some change).
I cut the lower radiator hose to get a non-squished section of it and put it back on, then set to shrinking it with a hairdryer. This is apparently a common problem with the new rubber that they make their radiator hoses out of - they just leak.
That didn't work very well. I have an old one that's only 1200 watts, and with the cold wind blowing a bit, it was nowhere near hot enough to really shrink the thing. After 10-15 minutes of that, I had it CLOSE to the hose, but nowhere near snug enough. I put all the coolant back in and started the car with a pan under it in hopes it would shrink even more. Once the thermostat opened up, the dripping got slower and slower, the fan turned on a couple times, and I figured it was good. I went on a 5 minute drive around the block and brought it back and parked it...only to find it STILL leaking.
You need the clamp to get really, really hot (John says ~300 degrees), so I'd recommend either having a REAL heat gun instead of a hairdryer, or do what I did and go make the engine really hot on some twisty roads. Once it shrunk to make a good fit, it completely stopped the dripping and the clamp has such a big surface area that it makes a very good seal on the lower hose.
Gates Radiator Hose clamps
Gates Heat-Shrink Radiator Clamps
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
SimLyons
- Year and Model: 2001 V70 T5
Yeah, I have read about them and they are available on line, too.
Harbor freight has a really good price on real heat guns (1500 Watts on low, 3000 on high) and the price is around $22-25, depending on sales coupons, etc. I'm replacing all of my critical coolant hoses with the shrinkable ones this spring.
Sim
JDS60R
- Been thanked: 3 times
Harbor freight heat gun on sale $13.99
http://www.harborfreight.com/1500-watt- ... 96289.html
Great for the Gates Powergrip SB clamps. I get my clamps from O'Riely's
I use the gun on high and you can see it shrink down quickly. You want to heat up at least 1/2 the clamp. If you over heat it the clamp material will start to bubble. Just back away and it will be fine per Gates. The slight bubbling doesn't hurt it.
Once it has been driving it will finish tightening. It will never over-tighten. It will self adjust each time it is used and tightens even more when it gets cold out. They will outlast the hoses. Over 4 million miles of R and D on these with no failures. Vehicles tested include tractor trailers running them for over 400,000 miles with no failures. Yest data stops at 400,000 miles as it was suggested to replace the hoses per their manufacturer.
I am addicted to these. No more come backs and the cars never leak. Keep in mind as leaks are now removed you should only be topping up with water as the water evaporates through the hose walls but the coolant remains.
Retired
jblackburn
JD, you forgot about the 28497238749239784 other places Volvos will inevitably leakNo more come backs and the cars never leak.
Heater core...turbo...expansion tank...ECT...etc.
But I'm quite happy. One more of my annoying little problems taken care of.
'98 S70 T5
- Has thanked: 311 times
- Been thanked: 817 times
How do you remove these?
Is it a throwaway when time comes to replace the hose (which would be fine!)?
precopster
- Year and Model: Lots
- Been thanked: 128 times
Does that mean I can use these on URO hoses and have no fear they'll leak?
jblackburn
Maybe...but URO hoses should all die in a fire to begin with.
I could see using a knife or cutting pliers to get it off, but you'd probably stab the hose a bit doing that.
Then again, if you have a working radiator drain that won't break (yay Nissens!, boo Valeo), the only reason you'd really be undoing it is to replace the hose or replacing the radiator, right?
'98 S70 T5
JDS60R
The gates Powergrip SB clamps are one time use and can be removed with a soldering iron. It causes no damage to the hose. A special thin T knife can be used but I don't have one.
I have had success with URO hose and these clamps but do prefer Gates or Volvo hoses. Especially on the heater hoses.
JBlack - these cars initially offended me with leaks as well. I have been able to remove those issues, except for the standard 150K failures of heater core and rad with the use of Volvo coolant and distilled/demineralized water, Amsoil engine oil and trans fluid and Gates powergrip SB clamps. The oil leaks and PCV box/breatehr box/flame trap clogging is eliminated with Amsoil if you are starting with a PCV system or engine oil seal that does not already leak or is rock hard. One of the aspects of oil that is often not mentioned is how it handles the seals and if it creates sludge due to break down or high burn off levels. This also makes a huge difference in the sensors lifespan.
By following the above every time I do a repair the cars run dry and clean. I use Volvo coolant because its the right one for the car. I use Amsoil so I don't have to deal with any leaks or clogs or sensors or EGR's that would clog or die prematurely. I use the clamps to stop the coolant leaks - especially at the oil coolers on the back of the oil pan. These clamps are the only way to go on that oil cooler.
I have three engines, one mine, others belong to customers or friends, That now have over 100,000 miles with this system and they are bone dry under the hood ,the sensors are still functioning within range (although if I see an oxy sensor with 100K miles on it - I'm changing it) and the breather box is still working fine. One of the engines is over 150K ,its my friends in GA and he still has everything original except for oxy sensors and a thermostat I threw in when I was flushing the coolant at 100K.
The hoses and clamps stay on until they leak or 8 years.
The Amsoil oil is changed once per year or at 25,000 miles (no turbo) or 15,000miles (turbo).
Volvo oil filter is changed every 7500 miles.
Volvo coolant is changed every 3 years.
Amsoil trans fluid gets changed every 60K miles (50K on turbos)
Timing belt and pump changed on time
Oxy sensors every 100K with Bosch direct fit.
The engine,trans and any differential or AWD unit gets a high strength high heat magnet to catch the slag and an Amsoil fluid repalcement.
That's the JD secret formula for Volvo 5 cyl success. (Its a secret because few listen, many argue and the successful keep it to themselves)
I am sure there are other products that may work. This is what I came up with over the last 28 years for me. It works every time for me so I am sticking with it. If I ever see it fail I will drop the product from the formula. I have used only this formula for over ten years now and I and my friends customers love it. Forgot to say this but I do like to use Shell gas here in TN.
Retired
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
Just a comment about the original problem - a too-tight hose clamp. My dad, a diesel truck mechanic for many years, taught me to tighten clamps only tight enough for the rubber to be even with the top of the holes in the clamp. I haven't used thousands of clamps, but in 40 years neither have I ever had a hose leak or come off at the clamp by following that advice.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- 38 Replies
- 13785 Views
Last post by 454cid
- 26 Replies
- 7027 Views
- 3000 Views
Last post by rguzz
- 3008 Views
Last post by wizechatmgr
- 22 Replies
- 3266 Views
Last post by MrAl
