2001 S40,auto w/ 140k on it..
My s40 takes 2 tries to start up when it's cold outside. It cranks strong(starter and battery replaced already),but it take dies as soon as it starts on the first crank,all is fine on the 2nd crank.
No CEL.
Any takers? Shop already had the car,they said it started up fine for them for 3 days,go figure the shop opens at 10am and it's warmer by then already.
S40 Cold Start Problems...
shelly4278
- Year and Model: s40 2005
I had a similar problem to yours on my 2005 S40. I had an electrical issue. I thought it was the battery! There was an electrical draw draining my new battery. Hope that helps.
That's great. Hopefully that solves the issue. I had the same problem recently. I replaced the battery first, which made no difference. When I did the repair, the little plastic filter on the old regulator was actually cracked and misshapen.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
Another thing I though of yesterday, but forgot to ask: Have you replaced the fuel filter recently? Might be time for a replacement. Those things get gunked up with deposits and can cause problems. If you are going to replace it, from what I've read, people on this forum typically recommend using OEM fuel filters. I think mine was a BOSCH.
- 3134 Views
Last post by nucci480
- 315 Views
Last post by tango_1000
- 14 Replies
- 2894 Views
Last post by boosteds40
- 1331 Views
Last post by maverill
- 869 Views
Last post by erikv11
