I have a 99 V70XC with 220K on it we just bought. It's been well cared for, seems to run fine, drove it two hours home with no problem. Shortly after that we heard a horrible screeching sound when she started the car. It's only done that twice. Now, seemingly when the car is warm and started it makes a rattling sound. It seems to be coming from the rear of the motor, but I just can't isolate it. It lasts a few seconds after starting, then you won't hear it again while driving.
It's also throwing a code for a 'large emissions leak'
Here's the vid:
Can someone tell me what this noise is? (video)
norcals95
- Year and Model: 95 850 Turbo Wagon
I had a Honda that did the same with a cracked manifold. The temperature variance causes contraction and expansion sometimes letting it leak and other times it sounded perfect.
RockVegas
- Year and Model: 1995 850 Turbo Wagon
I was kinda worried about the turbo having some bearing problems or something. It also made a really loud screeching noise twice recently and I wasnt wondering if it was related. Sounded,... kinda sorta in the turbo's area. I had my wife cut the car off when I heard it, it sounded pretty damn bad.
JDS60R
- Been thanked: 3 times
Remove the inlet pipe to the compressor side (silver side) and check the turbo shaft for in and out and up and down play.
Let us know what you found.
Retired
melonpaulie
- Year and Model: V50 2005
Did you find out what was causing the noise? Was it the manifold or heat shields? mine is doing it now.
- eriscentro
- Year and Model: 96 850, 01 S60
my 96' 850 made the same noise...I looked under the rear doors and saw that the heat shield between the gas tank and the exhaust system was COMPLETELY UNATTACHED as in literally sitting on top of the exhaust system, with nothing holding it anywhere
- 1526 Views
Last post by TheOtherside
- 1529 Views
Last post by ldenorio
- 16 Replies
- 3927 Views
Last post by Goldchemist
- 2161 Views
Last post by Richard_TD
- 2889 Views
Last post by Klausc
