Power service urgent
My wife said that the battery light came on and on the message center it said "Power service urgent". I started the car and no message was stored. I turned everything on to see if the message would come back but nothing. Checked voltage while the car was running with Heat, radio, all lights on and it read 13.5V. Do I need to replace the alternator? Should I go ahead and do this or wait until the message comes back?
95 850 NA 279K on 1st motor (78K on the 2nd)
06 xc90 FW 2.5T 86K+
gshadow325
- Year and Model:
its dying...will need a flatbed soon if this is not addressed soon, dont think your xc90 plays with you like that...thats your first chance, next time she'll not be so forgiving. LOL
1998 Olive Green V70 T5 Manual - 155k Awesome car
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded
2001 Nautic Blue C70 T5 Manual - 92k Not stock at all
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
2005 and later have an externally controlled voltage regulator. Don't throw unneeded money at it before getting it checked.
13.5 volts idling with lots of stuff on is fine. WHat is the voltage if the engine is at 2000 RPM with all the items on?
The voltage output will vary a lot of the newer system. CEM monitors a few things and can do cyclic high voltage with periods of lower than expected voltage to if monitored parameters indicate a need for sulphation reduction charge cycle.
An alternator with the Alternator Control Module (new name for the voltage regulator that communicates with CEM or ECM to receive and send signals about charging level) instead of a conventional voltage regulator will be more.
The alternator has a one way clutch in the pulley and those can fail and let alternator slip but usually it is noisey when you raise engine speed right after starting it. It is a screech but not like a slipping belt screech.
Voltage stayed at 13.6 while the engine was at 2000RPM. This is with the radio balsting, foglights on, headlights, heater on full blast with the interior lights on.
jimmy57
That is probably right on target for that system.
Make sure the wire connections on alternator are secure. Since yours is a Bosch fuel system engine the CEM is what is wired to communicate with the ACM/Alternator.
- 1767 Views
Last post by jimmy57
- 9968 Views
Last post by adrian22
- 17859 Views
Last post by kranz
- 2368 Views
- 3071 Views
Last post by RickHaleParker
