EGR pipe exhaust manifold
I have a 1995 n/a 850 and I just replaced the exhaust manifold. I got one side of the egr coupling into the manifold, but for whatever reason I can't attach the EGR pipe onto the other side of the coupling. The nut won't grab the threads. It looks as if the nut is too small for the coupling, but it is the original coupling and it came off just fine. Any advice would help.
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Chase (clean) the threads and use some hi-temp anti-seize as a lubricant. Tighten carefully (if with anti-seize)
If you are replacing the coupling with an OEM, it would't hurt to verify the thread size with a gage or caliper first.
Post a picture, if you can.
Thanks
Thanks
gr-64151map.pdf- (45.92 KiB) Downloaded 153 times
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 2616 Views
Last post by theWIFES_S70
- 19 Replies
- 7996 Views
Last post by misha
- 18077 Views
- 1066 Views
- 5210 Views
Last post by darrylrobert
