XC 70 Catylitic converter question
Chef Rhody
- Year and Model: V70 XC AWD 1998
Is it possible to get enough positive pressure due to a broken or blocked Catalytic converter to give the impression that the PCV system is clogged? I have a new PCV system but still getting vapor coming up from the dipstick. Thanks https://www.matthewsvolvosite.com/forums ... e=post&f=1#
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Sometimes it takes a few weeks to clear up. Did you clean the prots in the motor out? Did you have an EGR valve?
JDS60R
- Been thanked: 3 times
It would be highly unlikely they are connected.
The PCV after being replaced will only operate correctly if the connection to the intake manifold and intake pipe were cleaned at the same time. Many forget to clean out the vacuum tree or vacuum port as well as any connection your pcv has to the intake tube. There is sometimes a valve on the intake tube called a PTC that gets gunked up
Retired
- 4932 Views
Last post by MadeInJapan
- 339 Views
Last post by calvolvo
- 833 Views
Last post by girly64
- 636 Views
Last post by lummert
- 483 Views
Last post by rhalkyard
