-=2000 S80 T6=-
Oh I'm so syck right now. Was getting my phone replaced yesterday when a guy pulled in beside me with his 2k S80 T6... It was Quiet as a dang Mouse!!! i was like (@)_(@) Why can't I get mine to sound like that.. So it got me to thinking.. I'm in the middle of easter egging and looking for problem components..one of which may be the wire harness and or ECM . I have noticed but can't get a good enough foto of the #5 ignition coil on the S80 t6 engine...from what I have seen the orientation of this particular one is 180 degrees from the others...which may also mean I have my harness plugged in wrong as someone has mentioned to me already.. so I would appreciate if someone could snap a foto of your wire harness as it relates to all 6 ignition coils.. Also if you can give me the Color code for for the terminals from left to right for Cyls #4, 5, and 6 as if you were looking INTO the connector/ receptacle.
This is driving me Bananas because my timing appears to line up "Spot on" with the Crankshafte mark and the timing cover, I have fuel and spark but no power and it backfires so I think i have something wired wrong...I also have absolutely NO OBDII codes except the Occasional misfire... Thanks in Advance...
-=UB=-
Need a Foto from and S80 T6
UncleBoost
- Year and Model: 855 R, 1996
- 626 Views
Last post by MsVolvos802000
- 1417 Views
Last post by mydamnvolvo
- 16 Replies
- 2750 Views
Last post by CIK7
- 780 Views
Last post by nyc1836
- 1048 Views
Last post by Bigbill55
