How many shift solenoids?
99_xc70
- Year and Model: 1999 xc70
I want to replace all the shift solenoids and even the torque converter lock-up solenoid. What is the best place to get these from and are the shift solenoids a and b the same? Also is there a way to bypass or activate the torque converter lock-up switch so that I can have overdrive back?
precopster
- Year and Model: Lots
- Been thanked: 128 times
This may help. There aren't a lot of members who have removed the solenoids and replaced them.
From what I've heard doing this while the transmission is still in the car is a backbreaker.
VBX_ProdVolvoAW50_40LE_AW50_42LENEW.pdf- (118.84 KiB) Downloaded 433 times
AutoTransDiagnosis.pdf- (306.5 KiB) Downloaded 371 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
No way to bypass a bad solenoid.
A and B are the same. There's also one for the torque converter lockup. They're all in the cover at the front - and they are NOT easy to access. Total PITA.
I believe several of our vendors sell them - I would call around for the best price. Give Tasca parts (just google them) and FCP Groton a call and see what they want.
I just switched some used solenoids from a lower-mileage car into mine and it's been working great since.
- aw5042le solenoids.jpg (47.02 KiB) Viewed 3127 times
'98 S70 T5
2016 Chevy Cruze Premier
99_xc70
Thanks for the the picture, exactly what I needed to know. I know it will be a huge pain to change but right now I can only drive in and around the city because it will not shift into overdrive. It just stays in 3rd and as I go faster the rpm just keeps climbing! I will be searching out and buying some solenoids this week.
sockeye119
- Year and Model: '97 850 GLT
All PITA's are relative. last winter i changed the heater core in my wifes 740...12 hours. it took a couple of days to recover. then I found out I bought the plastic core that you guys said would not last. It didn't. this summer it blew again. That car sits in the lower drive now. i don't have the heart for that but her "new" 850 GLT needs some PNPswitch and solenoid help. I read the tutorial on PNP's I can do that. I can change the Turbo when I have the cash. Can My 56 YO back do the solenoid in place?jblackburn wrote:No way to bypass a bad solenoid.
jblackburn
Take care of the PNP switch first; see if it cures the problem (it can throw weird 'gear ratio' codes, etc).
If you need to do the solenoids, the hard part is getting the bolts off the cover. Most are accessible from the top or bottom, but 3 are really difficult to get to. I had to loosen the subframe from the bottom and hold it with a jack.
You've got about as much room as you can see here to work under the car.
'98 S70 T5
- 1816 Views
Last post by precopster
- 22 Replies
- 1929 Views
- 13 Replies
- 5459 Views
Last post by SuperHerman
- 1980 Views
Last post by 01_Nautic_V70
- 25 Replies
- 12181 Views
Last post by jmartin919
