We need 1 FR strut assembly for a 2001 S60 FWD for a Volvo owner in need. New or working/used condition. He drives his wife 60 miles 3x/week for cancer treatment. I'll pay your shipping costs.
Did you know? 🤔
1995 850 t5-R
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
polskamafia mjl
Has thanked: 10 times
Been thanked: 8 times
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Thu Jan 29, 2015 5:39 pm
January 15, 2015 - 273,156miles
Read actual mileage from cluster. Mileage reported was 273,156. Due to me installing the wrong odometer previously it wasn't working so I'm not sure what mileage this new mileage will be replacing. I'll have to roughly re-calculate the mileage intervals for things like the next oil change, TB change, etc.
Still working on getting a fully functioning instrument cluster.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Wed Apr 01, 2015 8:32 pm
April 1, 2015 - 275,046
Replaced copper contacts inside PNP switch with new ones sourced from http://www.partsmonster.co.uk/volvo-850 ... 9315-p.asp
Performed ATF drain & fill. Replaced with 4qts SuperTech ATF Dex III equivalent.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Apr 06, 2015 6:52 pm
April 6, 2015 - 275,046
Rotated tires front to back. Torqued lugs to 82 ft.lbs
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Tue Apr 14, 2015 10:40 am
April 13, 2015 - 275,046
Replaced PNP switch and set alignment. Code 322 hasn't returned.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sat Jun 20, 2015 1:05 pm
June 16, 2015 - 275,118
Replaced failing AW50-42 transmission with M56.
Installed new clutch and pressure plates, resurfaced flywheel
Replaced rear main seal
Replaced o-ring and gasket on turbo oil return line
Replaced turbo coolant drain hose with IPD silicone hose
Replaced brake booster vacuum hose
Replaced turbo vacuum hoses
Replaced front, rear, and passenger side motor mounts
Oil and filer change with Mobil 1 10W40 synthetic and Mann filter
M56 gear oil drained and replaced with Valvoline 75W90 gear oil
Replaced intake manifold gasket
Replaced engine oil dipstick
Money Shot M56 Swap.jpg (171.35 KiB) Viewed 1516 times
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Wed Jul 01, 2015 7:21 am
June 30, 2015 - 275,431miles
Replaced cracked coolant reservoir cap with blue Gates cap.
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Sun Jul 05, 2015 6:16 am
July 4, 2015 - 275,540
Replaced oil cap seal
Installed missing shift cable clip on shifter end of cables. Now I have reverse! :D (Part Number 3502507)
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Aug 24, 2015 9:50 pm
August 24, 2015 - 276,429miles
Replaced brake rotors and pads
Replaced front driver's side caliper w/ reman unit from Auto Zone
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Mon Sep 07, 2015 5:00 pm
September 7, 2015 - 276,597 miles
Replaced trunk struts
Replaced antenna mast
polskamafia mjl
Poland
polskamafia mjl
Re: 1995 850 t5-R
Post by polskamafia mjl » Tue Oct 06, 2015 1:57 pm
October 6, 2015 - 276,705miles
Replaced heater core with Swedish Car Parts Ebay heater core
Replaced heater core o-rings with OEM Volvo O-rings
Removed Volvo heater coupler in firewall and replaced with standard heater hose
Installed wheel well liner on driver front wheel
Replaced various vacuum hoses
Secured evap charcoal canister to frame
Replaced broken fuel tank to roll over valve fuel line
Replaced coolant expansion tank along with both hoses that attach to it
Installed IPD HD TCV
Replaced ECT temp sensor and temporarily repaired broken connector (no more rough idle and cooling fan works correctly now)
Replaced jumper wire between pins 6 & 7 on transmission plug
Installed wiring for reverse lights
Cooling system filled with OEM Volvo blue coolant and distilled water
