November 18, 2015 - 277,785miles
Replaced voltage regulator
1995 850 t5-R
Forum rules
- Been thanked: 2 times
Re: 1995 850 t5-R
Re: 1995 850 t5-R
January 10, 2016 - 278,516miles
Oil change with ~6.5 qts Mobil 1 5w30 synthetic
Mann oil filter
Replaced drain plug with magnetic plug
New gasket on plug
Inspection performed at Your Inspection Connection on January 9
Mann oil filter
New gasket on plug
- Been thanked: 10 times
Re: 1995 850 t5-R
You might make it to 300,000! Is it the original engine/trans/head?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Re: 1995 850 t5-R
mecheng wrote:You might make it to 300,000! Is it the original engine/trans/head?
Original engine as far as I know (the previous owner did not have any service records for the car unfortunately) but I replaced the transmission with an M56 this past summer. Hopefully I hit 300K
January 13, 2016 - 278,XXXmiles
Car in long term storage while I'm out of the country until May
Fuel stabilizer in gas tank
Battery removed
Wheels chocked, e-brake off
And I'm enjoying the Caribbean!
Re: 1995 850 t5-R
June 2016
Replaced blower motor
July 26, 2016 - 281,143miles
Tire rotation
Noticed excessive wear on inner edges of all 4 tires
Tire rotation
Re: 1995 850 t5-R
July 27, 2016 - 281,143miles
Replaced brake booster check valve
Replaced front driver side turn signal bulb and cleaned electrical contacts to eliminate fast turn signal blinking
Re: 1995 850 t5-R
July 28, 2016 - 281,185miles
AC system recharged and low pressure side schrader valve replaced at VIOC
Re: 1995 850 t5-R
August 4, 2016 - 281,373miles
Replaced control arms, end links, steering rack bellows, and inner and outer tie rods with Meyle HD kit from FCP
Alignment performed at Swedish Motors, INC
Re: 1995 850 t5-R
August 5, 2016 - 281,400miles
Replaced both front head light bulbs with 9006 bulbs
Re: 1995 850 t5-R
August 15, 2016 - 281,667miles
Oil change with 6 quarts of Shell Rotella T6 Synthetic 5W40
New Mann filter
New crush washer on drain plug
Gathered oil sample for oil analyses at Blackstone Laboratories
New Mann filter
Who is online
Users browsing this forum: No registered users and 1 guest
