IPD sale Volvo Parts
Did you know? 🤔
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
cmblackburn
Year and Model: 1998 S70 T5
Has thanked: 0
Been thanked: 0
United States of America
cmblackburn
Post by cmblackburn » Mon Jan 21, 2013 4:36 pm
January 21, 2013- replaced power steering pump with 97,000 mile '95 850 turbo's unit, flushed steering rack with compressed air. Replaced power steering fluid, serpentine belt tensioner, serpentine idler pulley, topped up coolant and washer fluid.
1998 S70 T5, 267k "The Blue Turd" Dead again, manual swapping
2004 S40 2.4i, 164k "Cosmo"
2001 Ford Escape XLT, 198k "The Magic School Bus"
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Fri Mar 22, 2013 11:23 am
March 21st, 2013- 220,660 miles-
-Replaced broken center console wood with gray plastic part from '98 base v70; put stock shifter back on. Fixed accessory power outlet wiring harness.
-Replaced DS mirror motor and glass from wrecked '98 V70. $23
-Replaced failed Driver's seatbelt with unit from '96 850- had been replaced in late 2000 per belt tag- $8.
-Repaired passenger's seat back- was not moving.
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Mon May 13, 2013 7:04 pm
5/13/2013- 221,300 miles- rebuilt drivers side CV axle with new inner and outer boots, topped off transmission fluid.
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Sat Jun 01, 2013 7:55 pm
Saturday, June 1st, 2013- 221,550 miles
-Replaced front struts/rear shocks, rear shock mounts, bump stops, bellows, front strut mounts.
-Had car aligned at Merchants- all within specs of brand new S70
-Topped off oil (Mobil 1)
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Thu Oct 24, 2013 5:50 pm
October 17, 2013- 222,899 miles
-Replaced alternator with re-manufactured Duralast unit
-Replaced 47-DL battery with H6-DL (Brand new) -$13 difference
-Changed oil- Mobil 1 High Mileage 10w-30 Full Synthetic, Bosch filter
-Checked tire pressure, topped up all fluids
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Mon Feb 23, 2015 9:36 am
August 2014- Installed brand new DEPO brand "Jewels", Volvo Jewel corner lamps
-Coolant flush at 228,800
-Replaced thermostat housing, thermostat- 230,000
-Installed spoiler- December 2014
-Installed H6-AGM Duralast Platinum battery- Dec 2014
-Oil change- M1 high mileage-221,800- Jan 2015
Cracked windshield- Feb 20, 2015
-Broken DS headlight wiper arm-Feb 21,2015
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Thu Feb 11, 2016 11:21 am
1/10/2016 241,039 Replaced cylinder head, timing belt and components, all related parts.
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Thu Feb 11, 2016 11:22 am
2015- V70R door panels, radio, door speakers, map pocket, Volvo rubber floor mats
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Tue May 02, 2017 9:13 pm
1/10/16 241,039 Cylinder head replaced (used unit with 101k miles, new stem seals and resurfaced), gaskets, turbo coolant hoses (iPd), upper radiator hose, coolant reservoir, full PCV system, ECT and connector, thermostat, timing belt and rollers/tensioner, Volvo spark plugs, cap and rotor
3/27/16 243,000 Tire rotation, passed safety and emissions inspections
5/22/16 244,783 Oil and filter change
12/17/16 249,718 Oil and filter change
12/25/16 249,900 Installed aftermarket radio (Pioneer DEH-X7800BHS)
12/28/16 249,940 Installed new rear deck speakers
1/4/17 250,003 Rotate tires
3/11/17 251,356 Passed safety and emissions inspections
3/27/17 251,719 Replaced throttle cable and throttle position sensor
4/15/17 252,288 Replaced J-Hose and air guide, bumper rivets, radiator mount
cmblackburn
Has thanked: 0
Been thanked: 0
cmblackburn
Re: 1998 S70 T5
Post by cmblackburn » Wed May 03, 2017 6:46 pm
5/3/17 252,568 Replaced stock injectors with "blues" from a 1999 C70 T5 w/ 129k, fixed dead cylinder #3. Reset ECU.
