IPD sale Volvo Parts
Did you know? 🤔
VML - 1997 Volvo 850 2.5L Sedan
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
xHeart
Year and Model: 1997 854 NA
Has thanked: 7 times
Been thanked: 17 times
United States of America
xHeart
Post by xHeart » Wed Feb 22, 2012 10:25 am
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +140mi/225km | 2001 V70XC 1st Owner +190mi/ +305km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
xHeart
xHeart
Re: VML - 1997 Volvo 850 2.5L Sedan
Post by xHeart » Sun Mar 18, 2012 7:52 pm
  • 17 Mar, 2012 - Drain and fill ATF 118364 mi (1 of 3), MOBIL 3309
  • 10 Mar, 2012 - Motor oil change 118300 mi, standard PENNZOIL 5W-30/MANN Filter
  • 03 Mar, 2012 - Coolant leaked, Inlet and Outlet heater hoses replaced
xHeart
xHeart
Post by xHeart » Tue Mar 05, 2013 12:36 pm
I have been busy with the repair and maintenance with the exceptional support from cn90 of Omaha, NE.
Practice safety, purchase OE/OEM parts only, and use proper tools and procedures. When in doubt run it by the MVS Moderators.
Oil and filter change is every 4-month, three times a year for a healthy PCV.
Now at 123,338 miles
  • March 2013 – Replaced Heater Core, and O-rings
  • February/March 2013 – Rebuild Steering Gear from JAC; Serviced U-Joint, and Steering Boot assembly; Switched to Valvoline Max Life for steering fluid
  • December 2012 – Installed Bilstein TC Shocks; All New Dunlop Signature II Serie.s tires
  • October/November 2012 – Complete Front Suspension with Bilstein TC Struts; Installed New Front Hub-Bearing; Rebuild Driveaxle from Raxles, and replaced both driveaxle seal; Inner and Outer Tie Rods, and boots, Complete Alignment
  • August 2012 – Timing Belt and Water pump
  • July 2012 – Complete PCV replacement; Serviced IAC valve and the throttle body
  • May 2012 – Replaced Transmission Torque Mount; Upper Engine Mounts
  • April 2012 – New radiator, thermostat, and hoses; Switched to Zerex-G05
disclaimer - I have a heated garage to work
xHeart
xHeart
Post by xHeart » Mon Apr 15, 2013 8:12 am
Engine oil level drops close to minimum mark. A quart of fluid disappears every four months, the oil change time. It has been like this for past three years.
After reading several MVS posts, it made me look at the REAR cam seals. The fluid collection was visible on the block, just behind the REAR intake seal, hence this maintenance task. See DIY by cn90 here http://www.matthewsvolvosite.com/forums ... =1&t=50752
  • April 2013 - Replaced REAR cam seals at intake and exhaust - Volvo part
  • April 2013 - Replaced cap, rotor, wires, and spark plugs
xHeart
xHeart
Post by xHeart » Thu May 09, 2013 6:18 pm
It crossed 125,000 miles recently.
It smelled transmission fluid when the air was running inside the cabin. It appeared wetter around the hoses. I noticed a tablespoon was accumulated on the air guide, hence decided to replace both transmission cooler lines.
Used following two MVS sources for this fix:
...by Jreed http://www.matthewsvolvosite.com/forums ... =1&t=54118
...by cn90 http://www.matthewsvolvosite.com/forums ... =1&t=55794
  • May 2013 - Replaced two transmission cooler lines
  • May 2013 - Checked the fluid level while HOT and engine idling, added 1600ml MOBIL ATF 3309 to make up for the lost fluid
xHeart
xHeart
Post by xHeart » Sat May 25, 2013 9:28 am
It is now reaching 126k-mi. Yesterday it passed another emission test.
After replacing the ATF cooler lines, I decided to catch up a little on my to-dos and prepared to take care of P0455.
See MVS source http://www.matthewsvolvosite.com/forums ... =1&t=54546
  • May 2013 - Replaced 2 four inch rubber section of vacuum line at the either end of roll-over valve. It is located near the fuel filter
  • May 2013 - Replaced Purge Value near the shroud
xHeart
xHeart
Post by xHeart » Mon May 27, 2013 8:09 pm
A rewarding memorial day weekend around the house. My two cars are running well. Once hot, engine and transmission is way too much fun for this lad.
This VML post is about the problem it had developed where the brake pedal would delay releasing the shift from P. Also the ABS and TRACS lights on dash would stay on for longer, and only go off after the daytime running lights come on.
After searching, and help from the folks at MVS, found this post http://www.matthewsvolvosite.com/forums ... =1&t=55868
  • May 2013 - Replaced ignition switch at the steering wheel.
xHeart
xHeart
Post by xHeart » Thu Jun 13, 2013 8:19 am
Various mounts at the engine would benefit from the investment on front suspension components. But these mounts also need replacement. I now have replaced all four mount.
This replacement has silenced idling in D-rive, like it is N-eutral. The gear shift in Sport is even smoother.
  • June 2013 - Replaced front-right motor mount near crankshaft pulley with OEM - Lemförder
xHeart
xHeart
Post by xHeart » Fri Dec 20, 2013 12:29 pm
Recently crossed 130,000 miles.
xHeart
xHeart
Post by xHeart » Tue Dec 24, 2013 5:34 am
