94 Volvo 850 GLT
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
volvo850black
Year and Model: volvo 850 1994
94 Volvo 850 GLT
Post by volvo850black »
11- April-2010 Replaced timing belt
11-April-2010 Replaced guage cluster with new OEM
11-Nov-2010 Replaced drivers side half axle with used OEM
05-April-2011 Replaced front Struts with Monroe and Spring seats with OEM
05-April-2011 Replace ball joints and control arms with new OEM
05-May-2011 Replaced spark plugs with champion platniums
01-Jun-2011 Replaced Fuel pump relay with used OEM
18-Feb-2012 Replaced Ignition ECM with remanufactured used from 96 GLT
18-Feb-2012 Replaced Cam Shaft Sensor with new OEM
18-Feb-2012 Replaced Crankshaft Sensor with new OEM
18-Feb-2012 Replace igniter with new OEM
MattC 94 854 NA and 96 855 turbo
