serpentine belt R & R
captainbill
- Year and Model: XC90 2005
I purchase a 2005 xc90 2.5 5cyl 10 days ago. Yesterday it started making noise and getting louder. At first it sounded like power steering pump veins were dry and wining. Reservoir has fluid in it. I wanted to remove the serpentine belt to diagnose but I don't see how to release the tension on the belt to remove it. Any suggestions?
Use a flashlight and look at the R bottom side of the tensioner. You will see a torx fitting. Get the right size torx bit and pull towards the front of the car to take off tension. The hard part is when you try to put the dang thing back on. Have fun!
95 850 NA 279K on 1st motor (78K on the 2nd)
06 xc90 FW 2.5T 86K+
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Having a third hand to hold the ratchet with the torx bit and keep the tensioner compressed while threading the belt on the pulleys makes the whole exercise a piece of cake. (I am thinking about a pet Octopus...)
In reality, since I only got 2 hands, I make a loop out of a couple large size zip-ties or coat hangers. Just make sure it is done safely.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 20 Replies
- 17507 Views
Last post by Hurtfeelings
- 21 Replies
- 5349 Views
Last post by viper69
- 22 Replies
- 35962 Views
Last post by erikv11
- 62 Replies
- 17891 Views
Last post by Shanestrait
- 33 Replies
- 10021 Views
Last post by Krons
