IPD sale Volvo Parts
1996 855R
Keep track of your Volvo's maintenance here. Keep track of what you did, when, and how much it cost.
Forum rules
appropriatenoises
Year and Model: 1996 855R
1996 855R
Post by appropriatenoises » Sun Feb 26, 2012 12:11 pm
Car was purchased a little over a year ago. Seems to me that the previous owner was very concerned about the appearances of a well maintained vehicle, but that in reality there was a fair bit of work needing to be done, and there still is! Purchased with 236k km, and now has 248k.
Feb 2011: -Tune up including spark plugs, cap and rotor
-PCV system replacement.
April 2011: -Timing belt, water pump and tensioner.
-Starter
Aug 2011: -Headlight lenses
-Tailgate rattle repair and struts
Jan 2012: -Cleaning of valves, fuel injectors
Feb 2012 -MSD coil and IPD spark plug wires.
-Steve
Past:
1977 240-crushed
1981 245-on a fenceline
1987 740-on a fenceline
1998 S70 T5M- sold.
1967 P220 (Amazon) - lofty ideal, not good for a pragmatist.
Currently:
1996 855R- paid more than I wanted, sunk in more than I should! But it's worth it.
appropriatenoises
Re: 1996 855R
Post by appropriatenoises » Thu Jan 10, 2013 5:19 pm
November 2012:
Replaced Exhaust system with IPD turboback. $1037
December 2012:
Drove to Alberta and found all the problems that cold weather reveals.
-Replaced Thermostat and ECT sensor ~$65 IPD
-Replaced Intercooler hose leading to throttle body (at intercooler end) ~$11 IPD
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Re: 1996 855R
Post by appropriatenoises » Thu Jan 31, 2013 5:05 pm
January 2013:
Replaced rear O2 sensor damaged when old exhaust broke behind cat. ($89 from Amazon)
Cleared Codes - None have reappeared
Car has failed emissions test for high Oxides of Nitrogen (NOX)
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Re: 1996 855R
Post by appropriatenoises » Wed Feb 06, 2013 10:08 pm
Feb 2013
-Repaired vacuum leak at PTC nipple
-Changed Spark plugs to NGK Iridium 6418 - previous Bosch Platinums showed signs of being "too hot", whitish insulator.
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Re: 1996 855R
Post by appropriatenoises » Fri Apr 26, 2013 8:53 pm
April 2013
-Tires and alignment (Eagle F1 all seasons)
-Broke lower shock stud attempting installation of IPD rear overload springs. Stud re-tapped. Will need to replace trailing arm at some point.
-Replaced wiper linkage/motor from pick-a-part.
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
appropriatenoises
Re: 1996 855R
Post by appropriatenoises » Wed Jun 19, 2013 4:20 pm
June 2013
Rear ABS Speed Sensors $225
Oil Cooler Lines $300
-Steve
Past:
1977 240-crushed
1998 S70 T5M- sold.
Currently:
Who is online
Users browsing this forum: No registered users and 3 guests
