Serpentine Belt Tensioner Bouncing
sweedish_taboo
- Year and Model: 1993 Volvo 850 GLT
I have searched and read a couple threads, but can't find an answer to my problem. On my 1993 850 n/a saloon with egr and auto trans, I replaced the serpentine belt, tensioner, and idler pulley. All of the parts were volvo oem parts. The belt is quiet, seems tracks straight, no squeals or chirps, but the tensioner bounces forward and back at idle. When I come off idle, it smooths out. I don't think this is normal. I popped off the belt and the alt, p/s and a/c pulleys all seem to spin smoothly and the pulleys appear round. Anyone else having this issue? I noticed that there are two tensioners, one for egr, and I'm starting to wonder if I bought the wrong one, but can't find any info on it. I just don't want the tensioner or other parts to fail prematurely from the dancing tensioner. Anyone else delt with this issue?
claymore850
- Year and Model: 850 T5, 244, V70 2.4
Did you check your belt alignment? sometimes just one small diference between the air conditioner compressor, makes the belt jump, and it varies the tension over the belt. Also check you idle, and with the air conditioner off check again.. Does you belt tensioner bearing is making some noise?
precopster
- Year and Model: Lots
- Been thanked: 128 times
What part number is the tensioner you bought?
sweedish_taboo
Thanks for the replies. The serpentine tensioner that I bought is oem #6842019. I have the early serial motor with egr. I'm not sure how exactly to check the pulley alignment. But there is no noise or squeal. I spun the pulleys by hand and they all feel smooth. I put in a new idler pulley. No bearing noise that I can detect. At idle the tensioner is bouncing, but when I give it gas and the rpm's increase, the tensioner settles down. Maybe the idle speed is too low?
precopster
From FCPs listing:
"Note: Volvo 850 Automatic Belt Tensioner. This tensioner fits all 1993 models with a manual transmission and some 93 850 models with an automatic transmission. You will have to locate the engine serial number on your timing cover to get the correct unit. This fits models with EGR before engine serial number 122376 and models without EGR before engine serial number 121674. "
Does yours fit the criteria?
sweedish_taboo
Yes, my 1993 auto with egr has engine serial 112040 so it appears that I have the correct tensioner.
Billc1015
- Year and Model: 1994 855 turbo
There was an update to the belt routing for a better contact on the alternator. With this update I believe there was a different part #. You may want to check the belt that you got and see if it is the new or old style.
I am here: http://tapatalk.com/map.php?vmpyn3
sweedish_taboo
The new belt that I got is the longer belt (#9186352) with the new routing that wraps more around the alternator. Are you saying that there is a different part number for the tensioner?
- 1613 Views
Last post by misha
- 1395 Views
Last post by Faust
- 1070 Views
Last post by mrscullini
- 30 Replies
- 4959 Views
Last post by regent
- 14 Replies
- 3972 Views
Last post by PeteB
