I am stumped. My rear running or night lights and brake lights do not work. Everything was fine the last I drove this vehicle about 6 months ago.
What does work:
- Middle window light and plate lights turn on with the headlights.
- Everything on the front of the car works fine.
- Rear signal and backup lights work fine.
So far I have:
- Tested all the bulbs, they work and are all the correct type of bulb that should be used.
- Pulled 6 bulb relays from our local pull a part and swapped them in an out, no luck.
- Metered a solid 12v coming to both rear panels. Metered 12v running through the panel.
- Replaced the brake switch with a known working one.
The only change I have found is two of the 6 bulb relays (the two different in color or size from the taller red one in my wagon) make the front corner markers light up when I hit the brake. Odd, but I guess I can assume the brake switch is somewhat working? Maybe I can drive this thing in revers to work instead?
Not sure where to go from here. I am thinking maybe the relay box connectors or loose or something, but I am not keen on ripping that all out just yet.
Any ideas? Thanks.
EDIT: Crud, wrong forum. Could a mod bump this to the right section? =/
Stumped about '90 740 Wagon tail lights
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You might want to move this to the 740 section.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
From which models did the failure units come? Was there a red failure unit among the 6? It was fitted to the 240, 740 and 940. In theory the other failure units shouldn't fit.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
