Hi,
I have an evap system code on a 96 850 turbo. Could this code include the gas cap? I know that someone on here also mentioned the evap control valve.
thanks
Evap control code
White850Turbo
- Year and Model:
It could be a problem with the gas cap, but is highly unlikely. The gas cap is not a problem spot on these cars, the evap valve is. It is normal to not hear a hiss when opening the gas cap. If you ever do replace the gas cap, you must use a genuine Volvo cap, which costs about $35, otherwise you'll have problems with it. Just replace the evap valve, clear the codes, and call it a day.
-Sean
1998 S70 T5 (Almost Stock)
- 3654 Views
Last post by kznforvolvo
- 398 Views
Last post by mika
- 258 Views
Last post by Clockboy
- 557 Views
Last post by jjmtjordan
- 953 Views
Last post by bmdubya1198
