Did you know? 🤔
02 xc70 help misfire
2001 - 2007 XC-70
xc70066
Year and Model: 2002
Has thanked: 0
Been thanked: 0
xc70066
Post by xc70066 » Sat Mar 03, 2012 4:08 pm
Thank you for reading my post, it is my first time posting here but I have gotten a ton of great info from here.
I recently was driving home and had my oil pressure warning of no pressure come on and found the car was puking oil. I diagnosed it down to clogged pcv which caused (so far) my cam seal to leak oil.
I washed the engine down trying to find the leak and the car started to run rough while leak searching due to what I speculate was from the engine washing. I tore everything down and found the lower pcv port clogged which I cleaned out and fixed. I put it all back together and also replaced the front cam seal.
The leak was fixed from that seal but the car was running terribly rough and was spewing raw fuel out the exhaust. I bought a scanner and got codes 0300, 0301, 0302,0134, I then went and changed the all plugs and the #1 & 2 cylinder coil pack. the car still ran rough but I let it run for a while and the white smoke started to clear and less fuel came out of the exhaust. I cleared the codes and they stayed off for a while but the cel came back on and I am still getting a code for 0302.
I do not know where to go from here.....please help me. The car has 143k miles and I also did the oil pan o rings 5k miles ago.
jking4020
Year and Model: 1997 850, 2001 v70xc
Has thanked: 0
Been thanked: 0
United States of America
jking4020
Re: 02 xc70 help misfire
Post by jking4020 » Tue Oct 08, 2019 8:41 am
Did you ever find out about the 0134 code? Its o2 sensor right?
RickHaleParker
Has thanked: 3 times
Been thanked: 543 times
RickHaleParker
Post by RickHaleParker » Tue Oct 08, 2019 9:20 am
Check for Air leaks at #2 intake.
Do a compression test.
Swamp injector #2 with #3, see if the misfire moves to #3.
Are you sure the smoke was White and not Gray, Blue, Blue-Gray or Black?
White is steam = coolant leaking into combustion chamber.
Gray, Blue or Blue-Gray = Oil.
Black is too much fuel.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
Has thanked: 316 times
Been thanked: 981 times
Trinidad & Tobago
Post by abscate » Tue Oct 08, 2019 7:14 pm
Ancient 7nyear old thread. The car is a toaster by now.
Time for some pHp code, Matt!
Link To Volvo Glossary
