1999 S70 NT
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
drkaeppel
Year and Model: S70 1999
Post by drkaeppel »
Purchased the car in October 2010 with 76,000 miles. Here's what I've had done besides oil changes, filters, other fluids:
Nov 2010 - All fluids replaced
Nov 2010 - Replaced Timing and Serpentine belts
Nov 2010 - Replaced Power steering hose
Jan 2011 - sway bar endlinks
Jan 2011 - Swapped out a clamp for coolant hose for overflow tank (it was leaking because previous owner put wrong kind on)
Jan 2011 - ABS Module (Fixed by MattyMoo :D )
Jan 2011 - ETM related issues - got the software update from Volvo & TB cleaned. No problems since.
Apr 2011 - Top engine mount bushing replaced
Apr 2011 - New fuel filter
Apr 2011 - Front struts replaced
Oct 2011 - New spark plugs and ignition coils
Oct 2011 - New harness looming for engine wiring harness
Car now has 98,500 miles, nothing extra has been needed since October last year. It's getting close to 100k, so I'll end up replacing the PCV system in the near future. Also time to do some brake work perhaps this coming Fall.
