Hi,
I bought a replacement windscreen washer pump for my 850, and cannot get it to fit properly.
It is identical to the one removed.
But there seems to be no way to create a seal between the reservoir and the pump to stop water leaking out.
Is there a connector between reservoir and pump that I have lost? Or am I just being incredibly daft?
Thanks
850 washer pump replacement
I'm looking at the exploded parts drawing for that, and it does not show an O ring, just the pump into the tank, with a sensor going into a hole right next to it. Check the parts places (FCP Groton, etc. to look at their pictures, and see if it lists any O ring...also, enter 'Volvo 850 Washer Pump" into ebay, and see if any of those come with seals of any type.
ed7
- Year and Model: V70XC 2005, 2001
- Has thanked: 2 times
The breakdown is a bit sketchy:http://www.volvopartswebstore.com/showA ... her%20pump
Find the leak and take the parts with you to the hardware store to find a seal that may work.
Ed
Ed
It is literally the hole in the resevoir that the washer oump fits into, there has to be a grommet or something there.
Not sure if I could buy anything of the shelf that wouldn't leak as it has to fit the resevoir exactly and have a hole in the middle for the washer pump to fit into.
- 36 Replies
- 24892 Views
Last post by StickyPocket
- 15 Replies
- 8837 Views
Last post by volvolugnut
- 1026 Views
Last post by Weee
- 4438 Views
Last post by bmdubya1198
- 5823 Views
Last post by JenniferWatts
