15% OFF AKEBONO CERAMIC BRAKE PADS
LIMITED TIME ONLY!
Akebono is a producer of brake system parts that hails out of Japan. It was initially established in 1929 when the Japanese had actually only produced less than 300 vehicles total. They offer two tiers of products including OEM products and aftermarket parts. Brake sales began in the U.S. as of 1980, and since then Akebono has established itself as one of the most widely used providers of brake parts in the country. A quality aftermarket part for most vehicles, Akebono provides the do it yourself mechanic with a great after market part that is reasonably priced. Akebono continues to provide quality brake system parts to automobile enthusiasts around the world.
Apply promo code "SPRING15" for 15% OFF and FREE GROUND SHIPPING.
on orders of $149 or more. Hurry, offer ends soon!
Benefits of Akebono Ceramic Pads:
Optimized ceramic formula for superior brake performance
Premium ceramic pads produce low amounts of dust compared to lesser quality brake pads with a metallic formula
Ultra quiet brake operation
Excellent initial effectiveleness; no required break-in period required
Rotor-friendly for longer rotor life; reduces the amount of possible groves found on the rotor surface
Ultimate upgrade for vehicles equipped with OE semi-metallic, organic or low-metallic brake pads
Available for most popular Import and Euro models at FCP
Akebono Euro series has a ceramic friction formula designed specifically for European models to eliminate brake squeal Shop Akebono on FCP Euro
Akebono Pro-ACT brake disc pads for Asian makes are made from an ultra-premium ceramic compound Shop Akebono on FCP Import
SAVE TIME & MONEY.
Shop our complete brake kits & get all the parts you need at one low price.
VOLVO PERFORMANCE
BRAKE KIT
Akebono EURO ceramic pads
ATE premium slotted rotors
Stainless steel brake lines
Teflon front/rear shim kits
BMW E46 PERFORMANCE BRAKE KIT
Zimmerman cross drilled rotors
Brake pad wear sensors
Brake pad silicone
AUDI BRAKE KIT (100 A6)
Brembo Rotors
Grown from a small family-owned local operation started in 1986, FCP has evolved into a world-class OEM car parts distributor.In 2000, FCP began selling Volvo and BMW parts online introducing the world to a revolutionary new way to buy auto parts. FCP now has coverage for all major European and Asian Import makes and models. FCP sells high quality Genuine, OEM and aftermarket parts sourced directly from the manucturers sold right to the consumer. Our low cost online model allows for a larger selection and bigger discounts over tradiitonal brick and mortar auto part stores.
Call us toll free at 877-634-0063 or check us out at FCP Stores
