97 850 has high NO fail CA smog by 100 over max
I just fail a smog check in California, my 97 850 has about 300,000 miles on it. It runs great with no check engine light. I did get a code a few moths ago for evap system. Will that effect NO levels? My levels at 15mph where 506 the max is 424, After decarbonizing it went down to 496, in addition two years ago at my last smog my NO levels were around 200. Cat was replaced a few years ago. Any suggestions, should i decarbonize again? Is it bad 02 sensors, one or both, or should I try something else?
Billc1015
- Year and Model: 1994 855 turbo
High NOx is caused by high combustion chamber temperatures. I would check your EGR system first. The EGRs main purpose is to reduce NOx by diverting a small amout of exhaust gasses back into the combustion chamber. Since the exhaust gasses were already burned, they cannot be re-burned and it will bring down the temperature.
Billc1015
Check your thermostat and cooling fan opperation. Also, did you notice if they put a fan in front of the car when testing it?
I am here: http://tapatalk.com/map.php?tzxwub
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
300,000 miles!
Use this if you can find it locally as shipping is high - One bottle for one tank with Chevron Super Unleaded
http://www.paragon-products.com/product ... co-503.htm
Independent Volvo Service - $10 Dollars if you can stop by
http://www.yelp.com/biz/independent-vol ... lnut-creek
Change to this oil 15-40W with the 503 and drive for one tank. Smog afterwards with another bottle of 503 along with Chevron Super Unleaded.
http://www.paragon-products.com/Swepco_ ... /sw306.htm
This a simple way to figure out if it is your engine or you'll have to start doing some detailed diagnostics for a car that age.
Independent can be very helpful give them a call as they also carry the motor oil although I do not know if it is the 15-40W. I buy my mine by the case of 24 Qts.
Bill,
I don't remember them having a fan during the test.
The temp gauge is always a little above center, which seems a little high. I will check thermastat.
sit22II,
I dont know of any vac leaks. I just got a P0442 for the evap system, there might be a leak there. I don't know if that would effect the NO
BKM,
I would love to take my car to independent but I live about 8hr away.
I have done two tanks of sea foam, along with decarbonizing twice. oh, and I use 20/50.
I will try your stuff.
sit22II,
BKM,
- MoVolvos
Check your local Porsche, Ferrari or Mercedes high performance shop to see if anyone carries it.sinclair wrote:Bill,
sit22II,
BKM,
Andial is familiar with the Product
http://www.andial.com/
For the P0442 this may apply to your car
Billc1015
If its in the same place as my 94 850, it will be behind the bumper on the driver's side by the wheel well.
I am here: http://tapatalk.com/map.php?mpqz4g
- 2052 Views
Last post by Dmck
- 5742 Views
Last post by Flybrk
- 589 Views
- 3685 Views
Last post by RickHaleParker
- 781 Views
Last post by 93Regina
