1988 Volvo 760 Turbo Wagon (Estate) 236K miles
I have a fuel gauge that only works under certain weather conditions along with an in tank fuel pump that may not be working. Before removing the sender and fuel pump, where does the ground (earth) wire from the sending unit attach to the body? I want to rule out a bad ground before getting any deeper into this repair. I have already found the connector in the left side well under the removable floor section.
Ground wire from fuel tank sending unit
- regent
- Has thanked: 2 times
- Been thanked: 12 times
See grounding point 13/22 at 31/13 and 31/11 location on page 49 of the following diagram: https://www.matthewsvolvosite.com/downlo ... iagram.pdf
I think yours should have a similar arrangement - RWD, right?
Before 'digging' you may want to check the related fuses and relay socket contacts for integrity and cleanliness
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- regent
You're welcome. Hope you do not have to get into the tank, but if you do, do it safely by the book
2015 BMW 335i
2015 BMW 335i
h20ham
- Year and Model: 1998 xc
Old expired link, anyone with this they can post again please
https://www.yumpu.com/en/document/read/ ... g-diagrams
So difficult to find
68 125 b18 4 speed
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
95 965 T shift controller in progress
05 xc90 rough idle
72 164e b30 5 speed
79 242 16v 5 speed
84 744 T 5 speed
86 745 T 5 speed
88 765 T aw71
91 745 T 5 speed
05 xc90 rough idle
- 1005 Views
Last post by mrmail
- 1087 Views
Last post by beigg
- 3372 Views
Last post by RickHaleParker
- 1831 Views
Last post by volvolugnut
- 293 Views
Last post by Sveedy
