2001 S80 Volvo Surges and Stalls
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
MrMan2012
Year and Model: S80, 2001
Post by MrMan2012 »
I'm new to the group. Hello everyone and thank you for having me. My 2001 volvo s80 sometimes surges at 1000rpm with no acceleration from pressing gas pedal. It also stalls sometimes at redlights when the gas pedal is not pressed. The code I am receiving is for the mass air flow system. I tried mass air flow cleaner and to no avail nothing changed. I've seen many of these issues with several different possible outcomes, but no real answer. Has anyone been able to put finger to the cause or at least come close?
fn42
Year and Model: 98 V70, 00 S80
Post by fn42 »
Grab a MAF from a junkyard and stick it in... a lot of them fail in a way that no amount of MAF cleaner will fix. You can try just unplugging it as well, I believe these cars will stay running w/o a MAF sensor
usually when a new MAF doesnt fix the issue its an electrical connection problem in which case the most common fix is to ziptie the wire to the MAF body, putting tension on the connector.
jameshemi
Year and Model: 1999
Post by jameshemi »
replace all your fuel filters
Legofan
Year and Model: 2001 S80 T6
Post by Legofan »
fn42 wrote:I believe these cars will stay running w/o a MAF sensor
It won't if the sensor is working, the engine will stall immediately if the sensor is disconnected. If the engine has other failures the MAf will not allow the engine to run. Disconnecting the MAF will allow you to drive it enough to get to a repair shop.
2001 S80 T6 Moondust sent to auction for scrap
