Low washer fluid light went on. I used the washer a few time since. Refilled the reservoir and it took a full gallon of washer fluid. Since refill, the sprayer will only reach about 1" up from the bottom of the windshield -- not nearly enough to actually wash the windshield. Possible the pump is gone or could something else be going on? If the pump is shot, how big a job is replacement? Should I go with a pick and pull pump?
Any thoughts?
Thanks, Guys and Gals.
'98 V70 -- Loss of Windshield Washer Spray Strength
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I bet the 3-way valve busted. It has a pressure relief valve that goes bad with age.
There's one right by the headlight, and another somewhere under the hood on a wagon.
Something like a $1.50 part at the dealer. It will spray fluid out of the opening there if it is bad.
'98 S70 T5
2016 Chevy Cruze Premier
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
And you need the fingers of a seven year-old girl to change that damn thing! I just did it and ended up removing the headlight, it was still a PITA.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
Reason #36 why you need a set of long needlenose pliers! Extremely helpful.
'98 S70 T5
echase76
- Year and Model: 1998 v70 T5m
I wish the 3-way valve I bought was $1.50. The one under the hood cost me $9 at my local dealer! But it did solved the no-spray issue on the passenger side i was having.
1998 V70 T5m Silver/Charcoal - 150K
jblackburn
Sorry bout that. They actually gave me a 3 way t-valve that doesn't really belong there, but I managed to make it fit and it won't blow out again.
I really need to just block off the flow to the headlight wipers as neither one of them works and it just wastes a ton of washer fluid.
'98 S70 T5
- E Showell
Justin wins the prize again, but I had my mechanic swap the valve out while he was doing the engine change so I did not need to torture my hands to make the change. Mechanic said the existing valve was split in half. Mine was a little more than $1.50 as well.
'95 855 auto (sold)
'95 855 auto (sold)
- 17 Replies
- 2992 Views
Last post by 850forum
- 1946 Views
Last post by Rattnalle
- 1368 Views
- 1338 Views
Last post by bmdubya1198
- 1282 Views
Last post by darrylrobert
