Temp drops while driving 2002 S80 T6
I own a 2002 S80T6 193,000 miles on it. The radiator was leaking so I had it replaced, last night while I was driving on the highway the temp gauge dropped. The temp didn't drop all the way down but dropped to between cold and normal. When the temp dropped I felt cool air from heater.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Did the temps go back up when you stopped? Might be a stuck open thermostat.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
big air pockets in the system. Started moving fluid then air. Bleed the system.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
Change the thermostat, the check engine light will be on because the ECU isn't happy with the engine temperature reading, it also tends to turn the radiator fan on high speed all the time, you should still hear it running for a couple of minutes after shutting the engine down, if the above fits the bill get the thermostat changed as it's letting the engine over cool which is burning fuel there probably isn't anything wrong with the temp sender unit - Had this on my V70 a couple of years ago, cheap and easy fix, if DIY make sure you soak the thermostat housing bolts with release oil for a day or two before undoing the torx head bolts, also consider replacement bolts from Volvo which cost very little and make the job easier next time - Mike
