Florida sun has totally dried out the rubber weather stripping that appears to start in the lower corners of the windshield runs up the sides all the way across the top and then down the rear window. Mine is cracked and pieces are broken out. Is it really all one piece? What is it called? How is it replaced?
Thanks,
Joe
2001 S60 2.4T 120K
Windshield rubber side weather stip
JRL
- Year and Model: Several
- Been thanked: 16 times
You mean the long plastic roof strips or something else?
Picture please
Picture please
Xcellr8
- Year and Model: S60 2001 2.4T
Thanks for the reply, no my question is not about the plastic/metal strips but rather the rubber that appears a part of those strips. I'll try to post photos later today.
Found this thread on the on the Detailing forum,
https://www.matthewsvolvosite.com/forums ... 29&t=46471
There the rubber strip and the trim are described as two pieces and that the rubber is also two pieces one for the front, and one for the back with the same on each side of the car.
So now my question is when looking at volvo parts websites, what are the rubber weather strip pieces called and/or even better, what part numbers do I need to order. I would need all 4 rubber pieces - both sides front, both sides rear.
Thanks,
Joe
2001 S60 2.4T 120K
Thanks,
Joe
2001 S60 2.4T 120K
JRL
That thread was no help at all
I just removed my roof strip to cut it tonight for Euro rail install and I have no idea what rubber you mean....
Xcellr8
Thanks for trying to understand JRL, I really do appreciate your attention and help. I must say though, that I find it amazing that there is a question as to what I am referring to. I'm almost positive that all S60 models have these rubber pieces. Wait for the the photos as my daughter has the car right now. Come back later to see. Thanks again, Joe
JRL
As said, I'll be happy to help if I knew which piece you mean.
Email me a picture
jrl1194(at)aol.com
Email me a picture
jrl1194(at)aol.com
Xcellr8
Here are some photos of the cracked and broken rubber weather stripping. One shows the rubber goes under the winshield trim piece. Another shows the rubber as seen from above the windshield, the last shows the rubber extending down the back window. It appears to be in good shape, but is actually cracked quite a bit.
I'm just trying to figure out what these rubber pieces are called (part numbers would be even better) and how they can be replaced as economically as possible.
Thanks for all you do.
Joe 2001 S60 2.4T 120K
JRL
Emailed you
JRL
Just emailed you again
These are part of the long plastic roof strips and not available as a separate rubber piece
Sorry
Sorry
aelancaster
- Year and Model: S60 2004
How do you replace them? Priced them at the dealer and they are $176.00 ea. plus labor ti install.
- 1402 Views
Last post by volvolugnut
- 3509 Views
Last post by MoVolvos
- 704 Views
- 2745 Views
Last post by Archer
- 991 Views
Last post by Stine
