To date I've managed to repair my 940 thanks to you all (brakes, e-brake, struts, strut mounts), so thank you for all the posts and pictures.
The Red Baron is not shifting into Overdrive, the Overdrive button on the shifter does illuminate but doesn't affect the transmission. The light was coming on intermittently prior to this event. Is this a Overdrive Switch issue or Neutral Safety Switch...no clue and no experience with either failing before. Any advice would be appreciated.
Thanks,
Greg
Boston, MA
1991 940 Turbo - No Overdrive
Thank you for the insight. I am familiar with the relays in the console above the shifter but don't know which relay does what and don't have documentation for the car. I can check with Chilton as i have an online subscription and have no idea where the solenoid would be...do you?
Thanks,
Greg
Thanks,
Greg
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Is this a 91 940 SE or just a regular 940 Turbo? The 91 940 SE is wired just like a 90 760. Is your fuse panel on the end of the dash next to the driver door or behind the ashtray?
1988 Volvo 760 Turbo Wagon
I ended up replacing the relay, no joy. I just replaced the solenoid, not an easy job very difficult position to get a tool into....Success!
The OD is working however, the knockdown button randomly goes on, i can always hit the button on the shifter but but I think there is a short or ghost in the machine.
- 975 Views
Last post by selsworth1
- 1487 Views
Last post by 93Regina
- 981 Views
Last post by s10lowrider1994
- 1338 Views
Last post by anothersullivan
- 980 Views
Last post by nisan17
