There are already some things I need to do to it. Like un-ghetto rig the boost gauge from the previous owner. I am looking to probably get the mirror pod thing that viva sells since I despise pillar pods. Not as much as duct tape though... The key fob for the keyless entry has the loop broken off so you can't attach it to anything. I have to get the rest of the headlight wiper parts and put all of that back together. Can anyone confirm that the 850 and v70 of this year use the same headlight wiper parts? I looked on IPD and they said that they were compatible. One of the fog lights melted the back of the part you plug the harness into so I will be buying new fog lights probably. Especially since these are kind of beat up looking. It needs and upper engine torque mount. Going to flush the coolant since it is the dirtiest green/brown color I have ever seen before. I also want to swap the new coolant expansion tank I just put on my 850 into this car. Bleed the brake system and add some stainless braided lines. The brake fluid looks pretty bad as well. I messed around with the hood latches until my patience ran out today. Hood still only opens on one side unless I wedge something under the corner of the grill. Went out this morning and there was a flat tire. I put 40psi in around 1pm this afternoon and made sure all the others were the same. Went back out about 20 minutes ago and its already lost 20psi. Didn't see or notice any nails, screws or other punctures. Who knows I suppose it could be a bent wheel as well. If so I have a brand new set of Persus wheels with brand new tires in my basement. If my allergies weren't so bad I would still be out there digging around underneath. I did put my super special rubber mat thing from my 850 into this one already. Ok its not special, anyone can buy one from Weathertech.
That is all I can really think of/remember or have found yet that need addressing. Now on to the pictures. I am sure I will be around asking questions. Should be getting tags tomorrow and my safety inspection done the next day along with that coolant flush. As well as having my friend give the car a good look over.
Just to be sure about this. Since I see these plugs unplugged on both sides of the car I assume that they are for the wiper motors. Am I correct?
