Sometimes and becoming more frequent my 4th gear runs a little high 70 MPH= 3000 and after five minutes or so it will gently drop 300+/- or so RPM to normal. This is starting to worry me, is this the beginning of the end?
Its like it has to warm up that 4th gear or something.
4th Gear runs a few hundred RPMS fast for a while.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Sounds like a sluggish TC lock-up. Change the fluid and use Mobil-1 Synthetic ATF. Might help. This helped another car I have that started having TC lock-up issues (a Subaru)
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The fluid temp sensor must register approx 125F before TC lock is enabled. Temp sensor bias can make it delay until an actual higher temp when sensor biases low.
Before you get too worried the car needs to be driven from cold with a scan tool and see if TC lock is occurring when trans temp is indicated as 50C or a bit above.
If the engine thermostat is sticking open it will keep ATF cooler and the delay could be engine cooling system related.
tblindt
- Year and Model: SPORTSWAGON 855 1994
Thanks Guys. I'll start with the finest Mobil 1 idea and then see if it continues. Far as the thermostat Is there a way to see if its staying open too long? I do have slight temp variation. What type of scan tool are you speaking of here?
1994 Volvo 855 Sportswagon 185k
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If you see any temperature variation driving down the road after 5 minutes, your thermostat is definitely stuck open and Jimmy's idea holds merit.
I have seen mine hold out on the torque converter "up shift" on cold mornings at 70 mph, so it does sound like it has to do with the temperature of the fluid.
'98 S70 T5
2016 Chevy Cruze Premier
- 11 Replies
- 2525 Views
Last post by 4sdAIR
- 925 Views
Last post by alschnertz
- 2493 Views
Last post by Clemens
- 2982 Views
Last post by Roger_850T
- 195 Views
Last post by dikidera
