I have a 1990 240 DL and I was wondering if a faulty coolant temp sensor could cause plugs to get covered with a black soot. I would think this sensor was only for the gauge on the cluster. I read on a response to a plug fouling problem which led to stalling that the sensor sends signals to the fuel system some how.
Thanks
faulty Coolant Temp Sensor 1990 240 DL
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The Engine Coolant Temperature (ECT) does supply info to the ECU. If it is faulty it should set a fault code 1-2-3.
Have you checked for fault codes?
You can check the ECT with an ohmmeter or multimeter. Readings should be as in the attached:
Ignore the year as it is the same for your car.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
broke wagon
- Year and Model: 240DL wagon 90
Bill,
Thanks for the feed back. I haven't checked the codes. Before I read your response I took a look at my car and noticed the cold start injector was unplugged. I haven't taken it out for a test run yet, but I am willing to guess that might be the cause.
- billofdurham
That's a good guess. Keep us updated please.
Bill.
Bill.
Previously:
Previously:
broke wagon
Hello Bill
I did get a fault code of 1-2-3. I also called IPD for some advice. They said the wiring harness that runs through the fire wall on the drivers side is known to cause problems. I still need to give that a good look. And also my ignition switch isn't working too well. You have to turn the key slightly to the left for the wipers and the radio. IPD also told me that could cause some problems. I still am going to give it a test drive in the morning and see how it goes.
thanks for the feed back
Glen
Glen
ordinaryboy1986
- Year and Model: 1993 Volvo 245
How did this end up? I'm pulling a 123 code
- 6106 Views
Last post by misha
- 2274 Views
Last post by ordinaryboy1986
- 5153 Views
Last post by Raindog92
- 11 Replies
- 9073 Views
Last post by oragex
- 1250 Views
Last post by 93Regina
