I know this information is here, but I have looked until my eyes are bleeding. If someone can provide links it will help much,
Fan does not run, lights flash. This is the auto AC unit
I have:
1. Checked motor and oiled bearings, still not sure it is not drawing too many Amps
2. Cleaned both D and P Temp sensors
3. replaced MOSFET on "resistor pack"
4. checked comp. air is very cold as the outside air coming from vents is cold when comp. is running
I need to know how to check codes and of coarse any suggestions
Does a 1994 come with the box under the hood to check codes? If so how to use.
Do I need a code checker?
Where do I find the meaning of the codes?
and do the codes really help the trouble shooting process?
I am an electronic tech are there schematics or Ohm checks for this unit.
1994 850 w/blinking AC lights
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Stop guessing!
The car will tell you what's up with it.
One of the advantages of having one of the older models is that you can read ALL codes from the underhood OBDI module.
Here's how:
https://www.matthewsvolvosite.com/read-codes-volvo-850
You want to pull and reset codes from port B2.
Here's how:
'98 S70 T5
2016 Chevy Cruze Premier
- Year and Model: Many Volvos
- Been thanked: 76 times
It is all in the factory service manual.
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
See the file named AC Heater System Auto.PDF.
What part number did you use to change the MOSFET?
Thanks for the down load, I used a IRFP048 I had laying around.
Update, I replaced the power stage, now the fan runs for about 2-3 seconds and shuts down. I get a 419 code, I assume the motor is drawing too much current.
Any sugestion are welcome
Thanks everyone
Thanks everyone
Ben850
- Been thanked: 7 times
Chances are, if the ECC unit is the original, it burnt up. I found that to be the case on my '93. The earlier year ECC had a flaw and evidently they all go bad. If you have the original one, that will most likely be the case. I found a guy on ebay selling them with a guarantee for $100. I have'nt had a problem with it and the codes that showed up after I installed it turned out to be accurate. i.e. passengers side temperature sensor code 126 on the OBD I , B1. After replacing that sensor and resetting the codes, No more blinking lights, and all my fan speeds work again with no new codes.
Good luck.
Good luck.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
You can easily check the ECC controller by popping it out of the dash and removing the cover. When they go bad there will be smoke marks on the inside of the cover and a big charred portion of the PC board near the electrolytic caps. I'm not sure of the compatibility of the MOSFET that you used. There was a good thread on Brickboard covering re-building the power stage and part of the writeup detailed how picky the control circuit was about the MOSFET.
http://www.brickboard.com/AWD/volvo/120 ... pdate.html
Thanks Lee
I have removed and checked the ECC controller and see no charred spots, I got a power stage from the salvage yard and now the fan runs for about 2 seconds(did not run at all before). I have order a new fan. The fan does not spin as easy as I think it should.
jblackburn
If it finds out the fan is drawing too much current it'll just cut it off before it destroys the resistor (at least theoretically). Sounds like you are taking the right course of action with replacement.
'98 S70 T5
- 14 Replies
- 4211 Views
Last post by RickHaleParker
- 4212 Views
Last post by foresthump
- 2855 Views
Last post by 850forum
- 4463 Views
Last post by aewoodhouse
- 3616 Views
Last post by BEJinFbk
