Hi everyone,
I just took my snow tires off, noticed that the rear ones are worn terribly on the inside of the tread. It's a tapered wear pattern, not scalloped. When standing behind the car the rear wheels look as if they are tilted inward at the top. It's my understanding that there's no adjustment for that on this model. Would worn bushings cause this? I replaced the pass side trailing arm linkage a while ago, and both rear bearing assys. The summer tires that were used after that show no uneven wear.
It is a wagon and I do haul lots of stuff in in as well as the ocassional trailer.
The rear of the car doesn't appear to be any lower than usual, but I have nothing to compare it to.
Any insight greatly appreciated.
1997 850 wagon
2.4 Liter
350,000 Kms
Rear tire wear
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Hi Krikkit,
Please find a link discussing rear alignment as it can be complicated and should be check out by a shop that has someone on staff that specializes in alignment rather than just a tire store or average mechanic. The exceptional Master Mechanic that I use is weak on Alignments and farms the work out.
https://www.matthewsvolvosite.com/forums ... =1&t=46949
- 11 Replies
- 2556 Views
Last post by icrashcars
- 1461 Views
Last post by oragex
- 12 Replies
- 4368 Views
Last post by lous_97_850
- 5682 Views
- 1916 Views
Last post by oragex
