re:- 1995 850 se 5cyl 2.5 est - 175.000 mls
whilst trying to cure my not starting probs, I cleaned theair intake area around the throttle butterfly, the plastic hose from the air filter box had a very small amount of oil laying in the bottom of it where in joins the air intake,
Also when the car is running (idle) I can see fumes coming from the engine crankcase breather hose, these fumes are obviously coating the air intake manifold and I have cleaned the area around the butterfly valve (throttle valve) and cleaned out the two little holes drilled in the manifold.
Question:- at this fairly high mileage is it normal to have a small amount of oil collecting in the bottom of the hose, (I mean small)
and, is it normal to see fumes coming from the engine breather.
I live in england and have old english cars as well as fiat, ford etc and on some have had oil coming out of everywhere when they were very old. But they still ran perfect.
My volvo does use quite alot of oil between oil changes, maybe 2/3 litres in 3/4000 mls.
many thanks steve
oil from engine in air intake Topic is solved
Guest
I will guess that the oil seperator is clogged.
Thankyou, could you advise as to it's where abouts.
Cheers steve.
Matthew, could you let me know what you think.
Cheers steve.
- Has thanked: 2861 times
- Been thanked: 1332 times
Sorry moonraker, don't know about this one, so I can't contribute.
White850Turbo
- Year and Model:
Is this a turbo model?
-Sean
1998 S70 T5 (Almost Stock)
- 1548 Views
Last post by 454cid
- 64 Replies
- 25236 Views
Last post by prwood
- 535 Views
Last post by erikv11
- 2665 Views
Last post by waynegarbo
- 39 Replies
- 8659 Views
Last post by precopster
