I have a 94 850 turbo, it will run fine up until about 4000-4500 rpm then just starts acting like its not getting fuel and wont rev any higher. It has no problem revving past 5000 in park or neutral, only when its in gear under boost.
I've checked the timing 3 or 4 times and almost positive its in time.
I've swapped out the ecu and injectors, no luck.
Anyone have any ideas what else could be the problem or where to look?
94 turbo not running after 4500 rpm
killjoysxe
- Year and Model: 850 94
killjoysxe
Idk if this is related but after i park after driving for a few minutes there is a hissing sound coming from the fuel lines near the fuel filter. i've looked and felt around but could not find where its coming from. Is presser build up in the tank normal?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Test fuel pressure at the end of the fuel rail while running on a hot engine.
I'm wondering if you have a bad fuel pressure regulator.
'98 S70 T5
2016 Chevy Cruze Premier
killjoysxe
I fixed the fuel leakage problem. I found two broken lines behind the fuel filter
I'm still having the revving problem though. I'll check the pressure tomorrow sometime.
killjoysxe
Now I'm having a problem with it stalling out when put into gear sometimes,
I checked the pressure and it was 55psi then i cleaned the pressure regulator out some then it was around 32-34psi.
killjoysxe
What kind of fuel pressure readings should I be getting?
