I was moving wires around and found that when I moved the plug on the black box fixed above the fan, to which a small air hose (VACUMN)runs to from the air intake, - the engine cut out - when I looked, the pins in the plug were much smaller then the holeS in the socket part, therefore not giving a very good electric contact, I have sqwashed the plugs a bit to make a good contact, (FOR THE TIME BEING)
WHAT DOES THE BLACK UNIT DO - IT IS CLAMPED ON BY TWO METAL BRACKETS AND IS NEXT TO THE FAN RELAYS ABOVE THE ENGINE COOLING FAN.
OH, GREAT SITE BY THE WAY!!!!
LITTLE BLACK BOX Topic is solved
- 1400 Views
Last post by rspi
- 1573 Views
Last post by jimmy57
- 1464 Views
Last post by Ben850
- 1984 Views
- 1596 Views
Last post by polskamafia mjl
