2005 XC90 T6
our dogs ripped it off while trying to get a squirrel or raccoon that climbed up into the engine bay....
that number reads 8645404
It not only looks like a drain line but also a Plenum as some Air Intakes. The chamber is to reduce noise. I could be wrong on the drain but for sure that part was made to reduce noise in a system somewhere and it sounds like AC at this time. However, it is just an educated guess. As for the hiss it would be the refrigerant going through the Expansion Valve from a liquid to gaseous state.jevilsizor wrote:correct me if I'm wrong, but a drain wouldn't make a hiss noise when I turn on the A/C...
