1990 240DL Wagon For Sale $1500 obo
broke wagon
Year and Model: 240DL wagon 90
Post by broke wagon »
Part replaced in the past year;
Both fuel pumps 286.22
Crank speed sensor 68.16
O2 sensor 105.99
All fuses/ distrib cap & rotor/ plugs & wires 50.00
fuel filter and fuel pump hose 24.64
Mass Air Flow Sensor (rebuilt) 197.74
IPD Exhaust system free flow 234.04
Fuel Pressure Regulator 73.44
Fuel Pump Relay 42.42
Used fuel control unit 200.00
Used ETC sensor 15.00
Power stage 69.72
Used ignition switch 25.00
Coolant temp sensor 15.00
25 amp Watertight fuse holder 15.00
Transmission seal replaced 30.00
replaced rear shocks
replaced rear taillight lenses
1428.73
1990 Volvo 240 DL
Stalls.
Transmission leaks at pan seal.
Odometer not working.
A/C doesn't work, might need a charge.
Rear center brake light not working.
Rear Hatch are left side fitting broke off. I think the hinges need to be replaced.
Rear defrost not working. Wires worn were they go through the hinges.
Missing Seat Adjustment knob on drivers seat.
Center Emergency Brake Counsol missing.
Hinge for folding down rear seat missing.
I think the car had been in a wreck at one time. I notice the paint on the back drivers side door is
a different shade of white.
Missing long section of moulding on drivers side.
Windshield seal leaks water on drivers side.
Body & interior in good shape.
Tires in fair condition. Good tread left.
Engine does run strong and sounds good.
Radio with CD player works
All power windows work.
Call with any questions 239 333 9758
