compression test on S60 T5 2001
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
volvos60t5x
Year and Model: s60 t5
Post by volvos60t5x »
Does anybody knows how much psi should i see on each cylinder?. I have replaced the pcv system and turbo and i started to see smoke again after 400 miles, for the there is 2 options, my valve seals, piston rings are gone or the turbo didnt come well repair.
priapism
Year and Model: 01 S60
Post by priapism »
I think it's more important that the numbers are even across the board. If one has a big drop off, it shows a problem with that cyl.
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
volvos60t5x
thanks, just want to hear a reference.
Quince99
Year and Model: S60 2001
Post by Quince99 »
I was given the figure of "over 140psi" by a Volvo specialist and a variance between cylinders of not more than 10%. This was for a S60 T5 2001 model.
